(ansyslmd) No features to serve, exiting (ansyslmd) EXITING DUE TO SIGNAL 36 Exit reason 4 (lmgrd) ansyslmd exited with status 36 (No features to serve)
January 25, 2023 at 7:28 amFAQParticipant
Common Vendor Daemon “CVD” changes were made in 2020R2 license manager’s “ansyslmd” vendor daemon to support increments with embedded encryption for ansyslmd ansoftd hclmd apacheda DYNARDO. Customer must install the 2020R2 license manager to take advantage of these changes.
- Q: How do I set the license server from my client machine?
- Failover feature ‘Discovery – Level 1’ is not available
- How do I configure RSM to send a solve to a remote machine (no scheduler)?
- Unable to start the Geometry or Mechanical Editor (Linux)
