Tagged: 19, BCs & Interfaces, fluent, fluid-dynamics, Fuel Cell, materials, Porosity, Reactions, species, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantThe electrical conductivity values that come into the potential equation are the actual values specific to the used solid or porous materials. The specified values include the fact that some of the used materials such as GDL and MPL are porous. In other words, the porosity does not find its way into the definition of the effective conductivity and into the potential equation explicitly. The conductivity of the the porous materials that are being used in fuel cells is considerably lower than the conductivity values for metals. Please note, the porosity of the material has a pronounced effect on the species diffusion, heat transfer and on the liquid water transport in PEMFC. Keywords: PEM, PEMFC, fuel cells, porosity, conductivity.
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
