I am creating an FGM PDF table from one of the Chemkin Model Fuel Libraries. While checking my properties under Species Model, I noticed that the Laminar Flame Speed table is all zeros. What does this mean?
Tagged: 19, Flamelet Models, fluent, fluid-dynamics, Species/Reactions
January 25, 2023 at 7:17 am
FAQ
ParticipantLaminar flame speed information is embedded in the Model Fuel libraries. To extract this information, the pdf-mixture properties must be set up correctly. To do this, open the pdf-mixture property and change the Laminar Flame Speed property to Laminar-Flame-Speed-Library. Then, generate your PDF table. If your PDF table is already generated, go to Species Model> Properties and click Recalculate Properties. To store this new information in the PDF, resave the PDF after the recalculation.
- How do I model humidity in Fluent?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- Model setup: Setting up chemical reactions
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How do I use the Flamelet Generated Model?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- How can volume fraction be plotted in a species transport simulation?
- LES Simulation of Turbulent Flames Using ANSYS Fluent
