Tagged: fluent, fluid-dynamics, Pollutant Models, Species/Reactions
January 25, 2023 at 7:17 amFAQParticipant
In a transient reaction case with a pollutant model active (NOx, SOx or Soot) you find in the Fluent GUI under “Run Calculation” “Advanced” the option “Postprocess Pollutants”. This option behaves in the following way: A. Start New Time step 1. Enable all equations other than pollutant equations Attention: This includes also deactivated equations 2. Solve all equations (other than pollutants) 3. Disable the above equations. Now enable pollutants 4. Solve Pollutants B. Go to A
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- LES Simulation of Turbulent Flames Using ANSYS Fluent
- How can volume fraction be plotted in a species transport simulation?
