January 25, 2023 at 7:16 am
FAQParticipantThe heat flux with which a mass flow enters a domain (or leave it) can be computed as: mdot*cP*(Tin – Tref) Tref is fixed in the code to 298.15K Comparing this with the heat flux computed using the total heat transfer rate from the flux reports there can be a large difference between these values. One possible reasons could be radiation. If a radiation model is activated, the inside of the domain exchange energy by radiation with the outside. The total heat flux is the sum of all heat flows across the boundary. It can be checked by also reporting the radiation heat flux and compute the difference. This should give the value computed the equation above.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
