January 25, 2023 at 7:16 am
FAQParticipantThe external emissivity is a thermal boundary condition and does not need any kind of radiation model as it is only used for calculating the heat flux from the outer boundaries of your domain and the environment. The only exception are semi transparent external walls with the DO radiation model – in this case it is used for computing the radiation heat flux between your domain and the outer environment. In all cases you have a corresponding external radiation temperature. The internal emissivity is used in combination with radiation models for calculating the radiation inside the domain. Values for emissivities are between 0 (ideal mirror, every incoming radiation is reflected, no radiation is emitted) and 1 (black body, every incoming radiation is absorbed). The values depend on the material and on how the surface was machined (e. g. polished).
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- Simulating Battery Pack Cooling System Using Ansys Fluent
