Tagged: 14, fluent, fluid-dynamics, scheme, udf, user-defined-functions
January 25, 2023 at 7:16 am
FAQ
ParticipantThe following TUI commands can be useful in stabilizing conjugate heat transfer simulations. (rpsetvar ‘temperature/secondary-gradient? #f) Will ignore secondary gradient on all the cells, but not the shell cells. (rpsetvar ‘temperature/shell-secondary-gradient? #f) Will ignore secondary gradient only in shell cells.
- Skewness in ANSYS Meshing
