Tagged: 2019 R1, fluent, fluent-post-processing, fluid-dynamics, post-processing
January 25, 2023 at 7:16 am
FAQ
ParticipantTo get access to the Surface Nusselt Number you need to have the following set: 1) In the Run Calculation Task Page (where you set the number of iterations), ensure you toggle on the Data Sampling for Steady State Statistics under the Options section (there is an equivalent one for Transient simulations). 2) When plotting values, you will find the variable under Unsteady Wall Statistics and then Mean Surface Nusselt Number.
- Skewness in ANSYS Meshing
