Discovery SpaceClaim: Geometry Repair – SpaceClaim Advanced Repair – Fixing Geometry Errors & Adjusting Repair Settings
November 2, 2022 at 9:17 am
SolutionParticipantSome models from other CAD systems import with errors that can be reported by the Acis modeling kernel (the engine that drives SpaceClaim). Sometimes the repair tools needs to be adjusted or tweaked to fix a model in a certain way. This tutorial shows how to Check Geometry in a model to find errors reported by the kernel, and how to fix them. This tutorial also shows tweaking tools like Gaps and Missing Faces to get a different result than the default repair method.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Detect Tool
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- FAQ – Share Topology is now available in Discovery 2021 R2
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Split Face in SpaceClaim
- Selecting all inner faces of a body
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
