Tagged: 3D mode, Cleanup, cut section, design, editing, Fill, geometry editing, geometry modification, modes, move, pull, Section mode, simulation preparation, Sketching
November 2, 2022 at 9:16 am
Watch & LearnParticipantIn this video you will learn about the section mode which can be activated by X on the keyboard. You can use Section mode to edit solids by working with their edges and vertices in cross-section. You can modify faces, edges, planes, cylinders, rounds, and chamfers in section mode. You can edit solids and surface bodies.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Working with Components
- FAQ – Share Topology is now available in Discovery 2021 R2
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Ansys Discovery – Detect Tool
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
