November 2, 2022 at 9:16 am
Solution
ParticipantIn this video, you will learn about the clearance tool to check small gaps such that a watertight fluid volume can be extracted. The Clearance tool detects small gaps between parts. Gaps between faces that are equal to or less than the distance you specified are highlighted in red and can be chosen to remove. The video features 2022R1, although the latest release of Discovery 2024R1, features more options under the detect tool. Please refer to this KM to understand how you can use the other detect tool options.
- Surface to solid creation in SpaceClaim
- FAQ – Share Topology is now available in Discovery 2021 R2
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Ansys Discovery: Automatic External Volume Enclosure
- Stitch Faces & Split Edges Tools in SpaceClaim
