Tagged: Analyze-FAQ, Ansys Discovery, Explore-FAQ, thermal
September 26, 2022 at 10:15 am
SolutionParticipantDownload the file here
Application example of a cold plate utilizing a convection region with a modified film coefficient to replicate the water flow through the cooling pipes. Below are the results of temperature distribution over the cold plate model. This project requires release 2020 R2 or newer.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Discovery Quick Tip- Understanding Contour Settings
- Ansys Discovery: Topology Optimization
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- How to Export to Fluent
- Thermal Analysis of Heat Sinks with Ansys Discovery
