September 26, 2022 at 10:15 am
FAQParticipantDiscovery – New Body Scoping feature
Under Simulation Options of Discovery, there is a feature called “New Body Scoping”. If you click on this feature, there is an option to “Include this in simulation”.
This option is enabled by default. It means that whenever a new body is created, it will get included in the simulation and the already solved simulation will go out-of-date. If you solve the case gain, you will now see results on the newly created body.
If this option is disabled, any new body will not get automatically included in the simulation. So the already solved simulation will won’t go out-of-date. You can use the Quick Scoping tool to include the new body in simulation, whenever needed.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Discovery – Defining new material
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
