July 4, 2022 at 7:00 am
Watch & LearnParticipantThis video shows how to locate bad quality cells in ANSYS Icepak. For the purpose of this demonstration, a chassis housing containing two fans is used. The model also consists of several other components. The video demonstrates several examples of bad quality cells that have non-positive volume or skewness values lying outside of the specified range. It then shows how to identify and locate them in the design in Icepak.
- ANSYS Icepak: Computing Metal Fraction and Thermal Conductivity of a Trace
- ANSYS SpaceClaim: How to change autosave interval
- ANSYS Icepak: How to open an Icepak tzr or an existing Icepak project in Workbench?
- ANSYS Icepak: Importing Geometry Using Libraries
- Quick Guide to HFSS Icepak Coupling
- ANSYS Icepak: Post-Processing Enhancements – Part 1
- ANSYS Icepak: Changing Materials For a PCB
- Creating Icepak-Compatible Objects in SpaceClaim
- Electrothermal Design of Power Converters for Electric Propulsion Systems – II
- Electrothermal Design of Power Converters for Electric Propulsion Systems – III
