June 6, 2022 at 10:33 amFAQParticipant
This is not directly possible, but the user can create a surface from the face using Concept//Surfaces from Faces. And then suppress the solid and finally export the geometry. You should be able to delete the created surface and unsupress original solid.
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: Weld Feature
- ANSYS SpaceClaim: Shared Topology
- ANSYS DesignModeler: Shared Toplogy
- How to move component within the assembly?
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
- ANSYS SpaceClaim: Imprinting Geometry
- ANSYS Workbench CAD Interface for CATIA: How To Create Named Selections and Parameters
