Tagged: ansys-workbench, parameter-set, parameters, Space Claim
June 6, 2022 at 10:33 am
FAQ
ParticipantYes there is a way but not directly in SpaceClaim:
In the “Parameter Set” tab of the Workbench project, you may click on a parameter in the “Outline of all Parameters” table and in the “Properties of Outline” table enter an expression for this parameter as a function of other SpaceCalim parameters.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS DesignModeler: Weld Feature
- How to move component within the assembly?
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
