3D Design
3D Design
ANSYS SpaceClaim: How do I parameterize patterns?
    • FAQFAQ
      Participant
      If a linear pattern is already created, then use the Select tool to select one of the instances. You now have the option to modify Count, Spacing dimension and overall dimension. Select one of the dialog boxes for either and click on Create Group in the Groups tab. (If a circular pattern is already created, your options are Count, Radius and spacing angular dimension.)
