June 6, 2022 at 10:33 am
FAQParticipantTo assign Gage Thickness to the Sheet Metal design, you need an xml file which has the required information such as material properties, and gage numbers with their corresponding thickness values. The xml file needs to be placed in the Materials folder of the installation directory. A sample xml file called ‘SheetMetal from MatWeb.xml’ is located at:
C:Program FilesSpaceClaimLibraryMaterials (default location)
The properly placed xml file enables the user to select that particular material by clicking the ‘Design’ in the Structure Tree and selecting it from the Library of materials in the Properties Panel. Assigning customized material and having the ‘Sheet Metal’ property set to ‘True’ from the properties panel enables the user to select the Gage Thickness.
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
