General
General
How to interrupt a meshing run without a pop-up window?
    • FAQFAQ
      Participant
      If the Meshing progress dialog-box is not visible then the best way to fix it is by resetting the ANSYS configuration stored in the Appdata folder. Save and close all open instances of Workbench Type %appdata% in the windows explorer address bar then browse to AppDataRoamingAnsys folder Here you will see a folder named v201. Rename that to v201_old. Now reopen Workbench project. The meshing progress dialog-box should appear.
