Tagged: ansys-fluent, fluent-meshing, Mirror geometry
June 6, 2022 at 10:32 am
FAQParticipantFor Boundary Meshes: Once in Fluent Meshing, you can read in a boundary mesh file. Then, go in the Menu to Boundary -> Manage
To Mirror your geometry, select one of the models that has been created and choose the option “Scale”. Scale it by -1 in the appropriate plane. This will invert it. Afterwards, you can translate or rotate the geometry.
For Volume Meshes: Once in Fluent Meshing, you can read in a case or the original mesh file. Then go in the Menu to Mesh -> Manage
To Mirror your geometry, select one of the models that have been created and choose the option “Scale”. Scale it by -1 in the appropriate plane. This will invert it. Afterwards, you can translate or rotate the geometry.
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
