June 6, 2022 at 10:32 amFAQParticipant
In the Meshing tool bar, click on ‘Annotation Preferences’; turn on the checkbox “Plot Elements Attached to Named Selections”. Click OK. Now you would be able to view the surface mesh (if the underlying entity is meshed) once you select the Named Selection in the Outline panel.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- How can I create a 2D section from a 3D model in SpaceClaim ?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS Workbench: Decomposition and Hex Meshing – Part II
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- ANSYS ICEM CFD: Basic Blocking
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- ANSYS BladeModeler Overview: Design of a Centrifugal Compressor
- ANSYS ICEM CFD: Swept Multizone Meshing
