June 6, 2022 at 9:58 am
FAQParticipantThis is post processing commands should be added under the ‘Solution’ object:
resume
strs_limit=100 !element with equivalent stress larger than this limit will be outputed
my_volu_all = 0
my_volu = 0/post1
set,last
allsel
*get,my_n_el,elem,,count !count of elements
etable,vonMises,s,EQV
etable,el_volu,volu
*cfopen,el_out,dat !open a dat file to write output
*do,i,1,my_n_el,1 !do loop over all elements
*dim,avg_vonMise,array,1,1
*vget,avg_vonMise(1,1),elem,i,etab,vonMises !get vonMise stress of element i
*get,i_volu,elem,i,volu !get element volume
my_volu_all = my_volu_all+i_volu !add element volume to total volume of the model
*if,avg_vonMise(1,1),gt,strs_limit,then my_volu = my_volu + i_volu !add element volume to volume with stress over stress limit
my_volu_ratio = my_volu/my_volu_all
*endif
*ENDDO
*cfclose
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
