June 6, 2022 at 9:58 am
FAQParticipantUse Display option available under the “Result” tab to “All bodies” to show unscoped bodies as transparent in result plots. The default is to only display scoped bodies in a result object.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
