How can I retrieve maximum membrane, bending and total stress from a linearized stress plot in Mechanical APDL?
Tagged: apdl, Bending Stress, Membrane Stress, Total Stress
June 6, 2022 at 9:58 am
FAQ
ParticipantOnce the linearized stresses are plotted through PLSECT command :
– Create an array to store values :
*dim,test_smb,array,3,3– Calculate the linearized stresses through PRSECT :
prsect– Use *GET function to store inside, center, and outside values for membrane, bending, and total stress :
*get,test_smb(1,1),section,membrane,inside,s,eqv
*get,test_smb(2,1),section,membrane,center,s,eqv
*get,test_smb(3,1),section,membrane,outside,s,eqv
*get,test_smb(1,2),section,bending,inside,s,eqv
*get,test_smb(2,2),section,bending,center,s,eqv
*get,test_smb(3,2),section,bending,outside,s,eqv
*get,test_smb(1,3),section,total,inside,s,eqv
*get,test_smb(2,3),section,total,center,s,eqv
*get,test_smb(3,3),section,total,outside,s,eqv– Use *VSCFUN to get maximum value for membrane, bending, and total stress :
*vscfun,memb_max,max,test_smb(1,1)
*vscfun,bend_max,max,test_smb(1,2)
*vscfun,bend_max,max,test_smb(1,3)
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
