June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video demonstrates how to efficiently create pretension bolts in a model and how multiple steps analyses can be used to analyze the design of your bolted assembly.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
