Tagged: mechanical, mechanical preload, structural-mechanics
June 6, 2022 at 9:30 am
Watch & LearnParticipantIn this video, we will see how to apply bolt pretension to a beam connection. We need to first create joints for each of the line bodies that represents the beam connections.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
