Tagged: ansys-mechanical, ansys-student, Contact denitiions
June 6, 2022 at 9:30 am
Watch & LearnParticipantIn this video, you will learn how to handle geometrical contacts in ANSYS Workench Mechanical.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
