June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video introduces the basics of creating a mesh in Workbench using ANSYS Mechanical. From the beginning to 5.51, you will learn how to generate FEA mesh for surface and solid bodies. From 5.51 to the end, you will learn the procedure for generating a quality mesh for each individual bodies using local & sweep mesh control feature. Learn more at http://www.ansys.com/studentcommunity
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to change begin node and element number for meshing in Workbench Mechanical?
- What is the difference between shell 63 and shell 181?
