Tagged: .STL file, adjoint, adjoint-solver, ansys, ansys-fluent, bounding surfaces, design, duct, fluent, optimization, optimize, Shape Optimization
June 6, 2022 at 8:45 amWatch & LearnParticipant
This video demonstrates how to use ANSYS Fluent’s adjoint solver to optimize the shape of an air duct within a space defined by imported bounding surfaces, improve the pressure drop and the outlet velocity uniformity, and export the improved design as an .STL file.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Left-handed faces troubleshooting
