June 6, 2022 at 8:45 am
Watch & LearnParticipantThis video demonstrates a general work flow that can be used to set up a fluid flow simulation for a centrifugal pump, with a volute, in ANSYS Fluent.
- Skewness in ANSYS Meshing
