How to avoid “Error: An internal has occurred. The Bounding Box evaluation for the contours failed” in Blade Editor?
June 6, 2022 at 8:32 am
FAQParticipantQ: When trying to create a FlowPath in BladeEditor, I get the following error: Error: An internal has occurred. The Bounding Box evaluation for the contours failed. Conext: ansFClientBMBladeDesign::Execute FlowPath How can this be avoided?
A: The sketches for the Inlet, Outlet, Shroud, and Hub need to be on the positive X side of the ZX plane. If the sketches are not on the positive X side, then this error can occur. Also, if any part of the sketch is not on the positive X side, then this error can occur. Please see the following for more information: https://www.youtube.com/watch?v=jKRzrj9d4gE
- Skewness in ANSYS Meshing
