June 6, 2022 at 8:32 am
FAQ
ParticipantFirst isolate the regions into separate domains. Set both laminar and turbulent domains to turbulent using SST. In the laminar domain, set Eddy Viscosity (under Advanced Turbulence Controls) to zero. This should approximate laminar flow in the laminar domain.
- Skewness in ANSYS Meshing
