June 3, 2022 at 1:43 pm
Watch & LearnParticipantThis video introduces the ANSYS Material Designer. Material Designer is an ANSYS application that enables you to model and analyze microstructures and derive homogenized material properties. It is characterized by the powerful creation of representative volume elements, an out-of-the-box parameterization of these as well as the provision of resulting variable material data to structural and thermal analyses.
- Introduction to ANSYS Material Designer
- ANSYS ACP: Lay-up Mapping of a Composite Spring
- Ply Staggering with ACP – ANSYS Composite PrepPost
- Ansys Material Designer – User Defined RVEs (Representative Volume Elements)
- Variable Material Properties Calculated in Material Designer
- ANSYS Material Designer: Calculating Variable Material Properties
