Materials
Materials
Variable Material Properties Calculated in Material Designer
    • Watch & LearnWatch & Learn
      Participant
      Material Designer is an ANSYS tool for the homogenization of microstructures, enabling you to model and analyze composite materials at a microscale to obtain homogeneous properties. Using a woven fabric draped over a dome-shaped structure as an example, this video demonstrates how to use Material Designer along with ANSYS Composite PrepPost to determine variable material properties as a function of shear angle.
