March 2, 2022 at 3:28 am
FAQParticipantBy default, for most of the nonlinear analysis the stiffness update is done for each iteration in Ansys. But how to update the stiffness during the nonlinear Newton Rapshon solution procedure can be controlled with NROPT command.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
