April 17, 2020 at 10:32 am
Mahmoud Taki
SubscriberHello,
I imported a mesh and geometry from 3-matic (an CAD software) to ANSYS WB and ran static structural. However, the same error keeps appearing stating that about 4 elements are of zero volume terminating the solution process.
I have attached the output of the solution. I just want to know the source of this problem and is there a way to solve it.
Thank you.
April 17, 2020 at 1:32 pm
Forum ModeratorIf you're deforming the mesh are you generating poor cells? The Materialise meshes are usually fairly good for Mechanical, so also check quality in 3Matic too.Â
- The topic ‘Zero Volume in Element Error on Imported Mesh’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1414
1241
1118
1015
