May 2, 2024 at 10:25 am
ansys beginner
SubscriberHi,
when I do a solar load calculation and i create a .txt file as you see below. I get only values for the first day. do you know why I get 0 for the rest of time steps? and the values of solar irradiation for the first day are also are a bit high for a winter season in spain.
"report-def-0-rfile"
"Time Step" "report-def-0 etc.."
("Time Step" "report-def-0" "flow-time")
0 0 0
1 0 3600
2 0 7200
3 0 10800
4 0 14400
5 0 18000
6 0 21600
7 0 25200
8 0 28800
9 0 32400
10 87.37472 36000
11 398.7988 39600
12 577.6913 43200
13 683.797 46800
14 729.4261 50400
15 716.548 54000
16 644.7245 57600
17 509.3973 61200
18 284.3901 64800
19 2.088976e-14 68400
20 0 72000
21 0 75600
22 0 79200
23 0 82800
24 0 86400
25 0 90000
26 0 93600
27 0 97200
28 0 100800
29 0 104400
30 0 108000
31 0 111600
32 0 115200
33 0 118800
34 0 122400
35 0 126000
36 0 129600
37 0 133200
38 0 136800
39 0 140400
40 0 144000
41 0 147600
42 0 151200
43 0 154800
44 0 158400
45 0 162000
46 0 165600
47 0 169200
48 0 172800
49 0 176400
50 0 180000
51 0 183600
52 0 187200
53 0 190800
54 0 194400
55 0 198000
56 0 201600
57 0 205200
58 0 208800
59 0 212400
60 0 216000
61 0 219600
62 0 223200
63 0 226800
64 0 230400
65 0 234000
66 0 237600
67 0 241200
68 0 244800
69 0 248400
70 0 252000
71 0 255600
72 0 259200
73 0 262800
74 0 266400
75 0 270000
76 0 273600Regards
May 2, 2024 at 10:27 am
ansys beginner
SubscriberÂ
my email is Removed - Rob so I can send you my files if you want to have a look
May 2, 2024 at 1:21 pm
Forum ModeratorPlease keep the conversation on here so others can learn. I suspect the tool doesn't understand that hour 25 on day 1 is actually hour 1 in day 2. The function was intended to assist in setting conditions and not for running many days of calculation with one hour time steps.Â
Re the values, did you alter the sunshine factor and assume fair or theoretical weather? The tool doesn't account for cloud cover.Â
May 2, 2024 at 1:32 pm
ansys beginner
Subscriberi kept fair weather condition and i did not touch sunshine factor, sunshine factor is equal to 1, how can I make ansys that timestep 25 is the hour 1 in day 2? should not ansys already understant this part?
- The topic ‘zero values IN TXT FILE IN ansys fluent’ is closed to new replies.
5664
1890
1414
1304
