May 29, 2024 at 2:54 pm
chatte29
SubscriberI am trying to design a helical coil and I have a couple of problems.Â
1) I want rectangular cross-section not square.Â
2) The geometry throws an error if the radius change is not at least twice the radius of the cross-section! How is the radius change defined---? I want the turn to turn clearance to be small- say for a rectangular cross-section of 10mm by 5 mm and in-between each turn only 0.1 mm gap. Is there a way to manually make this design in ANSYS?Picture 1 (what I have right now)- Turn-turn gap at 6mm (measured) for a square cross section of 9.9 mmx9.9mm.Â
What I want: Turn-turn gap at 0.1mm for a rectangular cross section of 9.9 mmx4.5mm.3) Say I have such two copper flat spherical coil axially lined up. How do I calculate their capacitance?Â
May 30, 2024 at 3:16 pm
GLUO
Ansys EmployeeHi,
Please use Draw>>User Defined Primitive>>SegmentedHelix>>RectHelix to draw it. You can define the width and height of the cross-section as well as other parameters.
May 30, 2024 at 3:40 pm
GLUO
Ansys EmployeeFor capacitance, you can use eletrostatic solver, assign voltage to the coils and get the capacitance between them.
- The topic ‘Zero pitch Helical Coil’ is closed to new replies.
6034
