July 4, 2025 at 9:00 pm
scabo
SubscriberHi, I am slightly confused with y+ values for different turbulence models. For k-e mode, y+ is around 30-300 and for k-w it is around 1. Is that correct? For RSM models based on k-w, the y+ should be around 1 right? And also, for RSM models, based on k-e, y+ should be around 30. Am i correct? In short I want to know, if I am choosing RSM model , BSL and Linear Pressure Strain, what will be the y+ values and wall funtions? Should i choose standard or scalable wall functions? thanks, any help is appreciated.
July 8, 2025 at 8:07 am
rademacherdacostacabral.v
SubscriberHi, the documentation regarding this subject is pretty well written in my opinion. As far as I understand the k-e-model must be used with a wall function as it can not compute the boundary layer by itself even when using a mesh with very fine resolution (low y+).
K-w-model is more flexible as it can do both:
"Ideally simulations should be computed with meshes whereis 1 , however this requirement is not always easy to achieve, especially in industrial computations at high Reynolds numbers and with complex geometries. It is also not always possible to create pure wall function meshes with
> 30 on the entire geometry. Wall-formulations have therefore been developed which smoothly blend between the two limits. Such formulations are termed "
-insensitive near-wall treatment"."
- https://ansyshelp.ansys.com/public/account/secured?returnurl=///Views/Secured/corp/v242/en/flu_th/section_kbf_dl4_vvb.html
https://ansyshelp.ansys.com/public/account/secured?returnurl=//Views/Secured/corp/v242/en/flu_ug/flu_ug_k_epsilon_setup.html
https://ansyshelp.ansys.com/public/account/secured?returnurl=//Views/Secured/corp/v242/en/flu_ug/flu_ug_k_omega_setup.html
3792
1388
1188
1095
1015
