Y plus value for Realizable K Epsilon model with Scalable Wall Function
    • prathikshetty
      Hi all,
      What should be the Y plus value range , when using Realizable K epsilon Model with Scalable Wall Function?
      Thanks & Regards
      Prathik
    • Amine Ben Hadj Ali
      The min  yplus here is always 11.225. It is good for log-wall mesh where in some regions the local grid get refined (perhaps accidentally or due to meshing methods) and the log-wall function will then deteriorate the calculation. Using scalable wall function will avoid that deterioration.
      A near wall investigation will always require at yplus in the vicinity of 1..to 5. A thermal analysis with Prandtl number larger than one will be even more restrictive.
      Please mark this as Is Solution if the answer helps you.
  • The topic ‘Y plus value for Realizable K Epsilon model with Scalable Wall Function’ is closed to new replies.
