July 14, 2020 at 10:33 pm
maliuzair
SubscriberI want to read the file (experimental results) and compare with the simulation results on XY-plot in the same window using text user interface TUI.Â
1) For reading the file i use /plot/file/file-name. It plots the graph but it doesn't load the file in the FILE DATA section of XY plots.
2) For plotting XY-plot of the simualtion, i want to create an animation. For that I useÂ
/display/open-window/2
/plot/solution/total-temperature
;; node values? [yes]Â
yes
;; zone id/name(1) [()]Â
;; surface id/name(1) [2]
axis-2
;; surface id/name(2) [()]Â
/display/set-window 2
/solve/animate/define/define-monitor "sequence-1" 2 yes no 10 xy-plot ppm "./anim/"Â
BUT it doesnt select the surface "surface id/name(1) [2] ". the animation is created but it plots something else (pic attached)
What am I missing?
July 16, 2020 at 7:16 am
Keyur Kanade
Ansys EmployeeYou gave empty zone id while using plot. Please try giving zone id.Â
Can you please try it once through GUI to make sure that it plots and create animation.Â
Keyur
https://www.youtube.com/watch?v=SsORGWCg1ss
If this helps, please mark this post as 'Is Solution' to help others.
July 16, 2020 at 9:30 am
maliuzair
SubscriberDear kkanade,
The problem still persists. Animation is created but wrong animation is created. It doesnt happen with contours, but only with xy plots.Â
Also, if you can please tell if there is a way from TEXT USER INTERFACE to load a file in "Solution xy plot" section "file data"
July 20, 2020 at 5:31 am
Keyur Kanade
Ansys EmployeeYou are using correct TUI for animation.Â
Please check the path for animation.
Also make sure you can plot those plots using GUI.Â
Keyur
July 21, 2020 at 9:01 am
maliuzair
SubscriberI double checked everything. Its just doesn't work with XY-plots. Finally, I had to write journal file using GUI which works.
Regards
July 21, 2020 at 2:54 pm
Forum ModeratorTry putting "axis-2"Â some of the commands need the quote marks.Â
July 24, 2020 at 8:29 am
maliuzair
SubscriberDoesn't work either. "Invalid command"
Regards
July 24, 2020 at 1:05 pm
Forum ModeratorHave you initialised the model?
July 24, 2020 at 2:38 pm
maliuzair
SubscriberYup I did. The error is "> invalid command ["axis-2"]".
without quotation marks, no error.
Regards
July 24, 2020 at 3:20 pm
Forum ModeratorRun the commands through step by step manually to double check you've not missed a () or yes/no in the command.Â
- The topic ‘XY-Plots from text user interface’ is closed to new replies.
- affinity not set
4102
1487
1318
1156
