October 20, 2022 at 3:27 am
Islam Zaid
SubscriberHello,
I am going to buy workstation to run ansys. This workstation contains processor xeon e5-2683 v4, but my friend told that he tried the se configuration and ansys discovery was crashing avery time, just when he opens the ansys discovery the workstations urgently shuts down. What is the suitable specs for ansys discovery and wht do you expect the error that faces my friend?
Your rapid response is highly appreciated.Â
IslamÂ
October 20, 2022 at 5:04 am
Atharv Joshi
Forum ModeratorHi Islam Zaid ,Â
I would suggest you go through the Hardware requirements for using Ansys Discovery before buying the workstation, please check this page given below.
Ansys Discovery Hardware Requirements (2022 R2) – Ansys KnowledgeÂ
Thanks and Regards
October 21, 2022 at 4:01 am
Islam Zaid
SubscriberAtharv Joshi thanks for your replay, could please figure out the reason for the problem that I mentioned urgently.
October 21, 2022 at 6:00 am
Atharv Joshi
Please check if your friend's workstation meets the Hardware requirements. If you are using Discovery Student License Version, please use Ansys Learning Forum for your queries.Â
October 21, 2022 at 7:23 am
Islam Zaid
SubscriberAtharv Joshi thanks, Another question please. Whether discovery uses gpu or cpu?
October 21, 2022 at 8:09 am
Atharv Joshi
Discovery Explore mode uses GPU for simulation. Please check the hardware requirements for both CPU and GPU requirements.
Regards
October 21, 2022 at 8:43 am
Islam Zaid
SubscriberAtharv Joshi but it seems that there is a problem. Kindly, I wend over the requirments, I made sure that the requirments are suitable as I told the machine are (2 x xeon e5-2683 v4 and RTX 3090). However that when running Discovery It seems that it uses the cpu for 10 secs after during doing the first simulation and then it shuts down urgently? This problem can not be figured out easily by the normal user when he goes over the requirments page.
October 22, 2022 at 4:11 am
Islam Zaid
SubscriberAtharv Joshi thanks sir, I already check and I could not figure out.
October 22, 2022 at 8:20 pm
Islam Zaid
SubscriberKindly, Is there any online support that can be connected to my PC and see what is the wrong with it? your response is highly appreciated.
- The topic ‘Xeon e5-2683 v4’ is closed to new replies.
5799
