April 2, 2024 at 5:05 pm
Ayushman Srivastava
SubscriberHi All,
I have one problem with compressible flow related to the micro-shock tube and DPM. I have to plot the x-t diagrams by doing post-processing. I need help obtaining these plots. Please advise me on how to obtain them in Ansys post-processing.
If it is impossible to obtain in Ansys post-processing, then which post-processing software do I have to use?
April 3, 2024 at 8:46 am
Forum ModeratorPlease can you post an example of what you're after? The contour data will show the flow results, and may be a better option?
April 5, 2024 at 2:41 pm
April 5, 2024 at 2:47 pm
Forum ModeratorOK, you'll need to review how point and line monitors are set up using Report Definitions and take data from Fluent to generate the plots.
April 5, 2024 at 2:51 pm
Ayushman Srivastava
SubscriberI don't find the information you provided helpful. Please elaborate or provide some sources to understand
April 5, 2024 at 3:09 pm
Forum ModeratorThey're covered in the tutorials, click on Help in Fluent and you should find them.
April 7, 2024 at 8:34 am
April 8, 2024 at 10:27 am
Forum ModeratorYou can't in Fluent, check Ensight, otherwise you may need to create the scale and then combine the images.
April 14, 2024 at 4:41 am
Ayushman Srivastava
SubscriberI am using the DPM model to inject the particles. I selected “group type” and “no. of stream= 20.” and my study is “transient”. A micro-shock tube is used, and the driver section is patched with a high-pressure gas and the driven section is patched with a gas at atmospheric pressure.
I am facing a problem: “Whenever I run the simulation at the same condition, in each simulation, the particle velocity at the nozzle exit is different, and the particle is reaching at a different time at the nozzle exit.”
Also, in each simulation, the message in the console is " the reverse flow on 168 faces of pressure outlet-12." appearing after every time step.
Why is it so?
April 15, 2024 at 8:59 am
Forum ModeratorAs I have no idea what the results or convergence look like it's a little difficult to comment. Please look through what you're doing carefully, then ask your question and include sufficient information for someone to have a chance of understanding.
- The topic ‘x-t plot foe shock wave problem in Ansys Fluent’ is closed to new replies.
5729
