October 27, 2024 at 1:50 am
Dato
SubscriberHello,
There is something wrong with dimension display in Sketch mode in a .scdoc file but it is normal before designing in this .scdoc file.Â
The large space should be a dot but it doesn't display. However, the dimension display becomes normal if I new a design.Â
I have tried to reboot SC but it doesn't work. I have tried changing something in Detail tab but it still cannot recover.Â
Any suggestion would be a great help.Â
Regards.
October 29, 2024 at 5:30 am
Charudatta Bandgar
SubscriberThis could be possible due to the regional language you have set in Windows. Can you check once? The decimal operator could also be the reason.
Regards
November 1, 2024 at 4:56 am
Dato
SubscriberI check it and shut down the computer for several hours and it works.Â
Thanks
5809
