June 22, 2023 at 9:34 pm
Salix Bair
Subscriber -
June 23, 2023 at 10:17 am
Forum ModeratorIs covered in the Fluent User's Guide. You may want to be a little more specific.Â
June 23, 2023 at 4:50 pm
Salix Bair
SubscriberI am trying to create an injection file to be read into fluent, what is the format that is required? I haven't been able to find any resources in the Fluent Guide on how to create an injection file not using Fluent.
June 26, 2023 at 7:57 am
Forum ModeratorYou didn't see this https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_sec_discrete_initial.html%23flu_ug_sec_discrete_file_props ?Â
June 27, 2023 at 4:26 pm
Salix Bair
SubscriberI saw that, but am not sure what the file extension is. I tried using ".inj" with the following formatting, and Fluent was unable to read the file and produced the following error:Â
Error: ASSQ: invalid argument [2]: improper list
Error Object: 3.53558e-05
((.02 Â Â 3.53558E-05 Â Â 0 Â Â 2 Â Â 0 Â Â 0 Â Â 2.00E-09 Â Â 296.15 Â Â 0))
((.02 Â Â 6.12395E-05 Â Â 0 Â Â 2 Â Â 0 Â Â 0 Â Â 2.00E-09 Â Â 296.15 Â Â 0))
((.02 Â Â 7.90619E-05 Â Â 0 Â Â 2 Â Â 0 Â Â 0 Â Â 2.00E-09 Â Â 296.15 Â Â 0))
((.02 Â Â 9.35496E-05 Â Â 0 Â Â 2 Â Â 0 Â Â 0 Â Â 2.00E-09 Â Â 296.15 Â Â 0))
((.02 Â Â 0.000106078 Â Â 0 Â Â 2 Â Â 0 Â Â 0 Â Â 2.00E-09 Â Â 296.15 Â Â 0))
((.02 Â Â 0.000117277 Â Â 0 Â Â 2 Â Â 0 Â Â 0 Â Â 2.00E-09 Â Â 296.15 Â Â 0))
((.02 Â Â 0.000127496 Â Â 0 Â Â 2 Â Â 0 Â Â 0 Â Â 2.00E-09 Â Â 296.15 Â Â 0))
((.02 Â Â 0.000136956 Â Â 0 Â Â 2 Â Â 0 Â Â 0 Â Â 2.00E-09 Â Â 296.15 Â Â 0)) -
June 28, 2023 at 9:13 am
Forum ModeratorThe wild card doesn't matter, Fluent will just read what's in the file. Try adding the header, and review the brackets. An easier approach is to write a DPM out file from a case and compare the formats.Â
June 29, 2023 at 3:12 pm
Salix Bair
SubscriberWhen I write an injection file from a case to compare the format, it doesn't match what is listed in the manual, this is what it looks like...
((particle_10nm_50000 ((type . inert) (injection-type . group) (cone-type . solid-cone) (numpts . 5000) (dpm-fname . " ") (surfaces . #f) (boundary -1) (stochastic-on . #f) (random-eddy-on . #f) (ntries . 1) (time-scale-constant . 0.15) (cloud-on . #f) (cloud-min-dia . 0.) (cloud-max-dia . 100000.) (material . water-liquid) (scale-by-area . #f) (use-face-normal . #f) (random-surface? . #f) (devolatilizing-species . #f) (evaporating-species . #f) (oxidizing-species . #f) (product-species . #f) (rr-distrib . #f) (rr-uniform-ln-d . #f) (evaporating-liquid-on . #f) (evaporating-material . #f) (liquid-fraction . -1.) (dpm-domain . none) (collision-partner . *dem-unknown*) (multiple-surface) (parcel-number . 500) (parcel-mass . 1e-09) (parcel-diameter . 1e-05) (parcel-model . 0) (drag-law . "udf LiuDrag::libudf") (shape-factor . 1.) (cunningham-correction . 1.) (drag-fcn . "LiuDrag::libudf") (brownian-motion . #f) (seco-breakup-on? . #t) (seco-breakup-tab? . #t) (seco-breakup-wave? . #f) (seco-breakup-khrt? . #f) (seco-breakup-ssd? . #f) (seco-breakup-madabhushi? . #f) (seco-breakup-schmehl? . #f) (seco-breakup-tab-y0 . 0.) (number-tab-diameters . 2) (seco-breakup-wave-b1 . 1.73) (seco-breakup-wave-b0 . 0.61) (seco-breakup-khrt-cl . 5.7) (seco-breakup-khrt-ctau . 0.5) (seco-breakup-khrt-crt . 1.) (seco-breakup-ssd-we-cr . 6.) (seco-breakup-ssd-core-bu . 1.73) (seco-breakup-ssd-np-target . 1000.) (seco-breakup-ssd-x-si . -0.1) (seco-breakup-madabhushi-c0 . 3.44) (seco-breakup-madabhushi-column-drag-cd . 1.48) (seco-breakup-madabhushi-ligament-factor . 0.4) (seco-breakup-madabhushi-jet-diameter . 0.001) (seco-breakup-schmehl-np . 1) (laws (law-1 . "Inert Heating") (law-2 . "Inactive") (law-3 . "Inactive") (law-4 . "Inactive") (law-5 . "Inactive") (law-6 . "Inactive") (law-7 . "Inactive") (law-8 . "Inactive") (law-9 . "Inactive") (law-10 . "Inactive") (switch . "Default")) (udf-inject-init . "none") (udf-heat-mass . none) (components) (volume-specification . zone) (volume-zones) (volume-bounding-shape circle 0 0 0 0 . 0) (volume-streams-spec . total-parcel-count) (volume-streams-total . 100) (volume-streams-per-cell . 2) (mass-input-on . #f) (rotation-on? . #f) (rot-drag-law . "none") (rot-lift-law . "none") (cone-type . "solid-cone") (uniform-mass-dist-on? . #f) (spatial-staggering/std-inj/on? . #f) (spatial-staggering/atomizer/on? . #t) (stagger-radius . 0.) (rough-wall-on? . #f) (cphase-domain . none) (x-pos . 0.002) (x-pos2 . 0.002) (y-pos . 1e-08) (y-pos2 . 0.004) (z-pos . 0) (z-pos2 . 0.) (ff-center-x . 0) (ff-center-y . 0) (ff-center-z . 0) (ff-virtual-origin-x . 0) (ff-virtual-origin-y . 0) (ff-virtual-origin-z . 1) (ff-normal-x . 1) (ff-normal-y . 0) (ff-normal-z . 0) (x-vel . 2) (x-vel2 . 2.) (y-vel . 0) (y-vel2 . 0.) (z-vel . 0) (z-vel2 . 0.) (x-ang-vel . 0) (x-ang-vel2 . 0.) (y-ang-vel . 0) (y-ang-vel2 . 0.) (z-ang-vel . 0) (z-ang-vel2 . 0.) (atomizer-x-axis . 0) (atomizer-y-axis . 0) (atomizer-z-axis . 1) (diameter . 1e-08) (diameter2 . 1e-08) (temperature . 300) (temperature2 . 300.) (flow-rate . 9.999999999999999e-21) (flow-rate2 . 9.999999999999999e-21) (unsteady-start . 0) (unsteady-stop . 0) (start-at-flow-time-in-unsteady-inj-file . 0) (interval-to-repeat-in-unsteady-inj-file . 0) (unsteady-ca-start . 0) (unsteady-ca-stop . 0) (vapor-pressure . 10000) (inner-diameter . 0.001) (outer-diameter . 0.005) (half-angle . 0.34906585) (plain-length . 0.001) (plain-corner-size . 1e-05) (plain-const-a . 4.9) (pswirl-inj-press . 1000000) (airbl-rel-vel . 100) (effer-quality . 0.08500000000000001) (effer-t-sat . 373) (ff-orifice-width . 0.001) (phi-start . 0) (phi-stop . 6.283185310001) (sheet-const . 12) (lig-const . 0.5) (effer-const . 0.3300000000000001) (effer-half-angle-max . 0.261799388) (ff-sheet-const . 3) (atomizer-disp-angle . 6) (x-axis . 0) (y-axis . 0) (z-axis . 1) (vel-mag . 0) (ang-vel-mag . 0) (cone-angle . 0) (inner-radius . 0) (radius . 0) (swirl-frac . 0) (total-flow-rate . 9.999999999999999e-21) (total-mass . 9.999999999999999e-21) (rr-min . 1e-06) (rr-max . 0.0001) (rr-mean . 1e-05) (rr-spread . 3.5) (rr-numdia . 10) (x-posr . 0) (y-posr . 0) (z-posr . 0) (x-posu . 0) (y-posu . 0) (z-posu . 0))))
June 29, 2023 at 3:21 pm
Forum ModeratorWhich isn't what 21.3.13. Point Properties for File Injections covers.Â
June 29, 2023 at 3:33 pm
Salix Bair
SubscriberNo, it doesn't cover the format written by Fluent. I have matched my format to that of the manual, Fluent won't read that format in. So on your suggestion, I wrote an injection file with the properties I want from Fluent, to see the format, which seems incredibly hard to replicate and there is no documentation on that format. I am just trying to write a file for a group of 500 particles, with a uniform diameter distribution, from the information listed in the manual this shouldn't be that difficult. I have READ the manual, I am looking for additional support to troubleshoot this which you don't seem to be able to provide.Â
June 29, 2023 at 3:43 pm
Forum ModeratorErm, the format you showed earlier is not the format in the manual, which is why I suggested adding the header. If you've since revised the file you might want to share it?Â
June 29, 2023 at 10:00 pm
Salix Bair
SubscriberI just copied and pasted the injection format from 21.3.13.1. Steady File Format of the manual to create a .inj file to be read into my case file. When I try to read the file in I get the following error:Â
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: z=4
July 3, 2023 at 8:31 am
Forum ModeratorIt worked OK here. Are you on Win10 or Linux?Â
July 3, 2023 at 3:24 pm
Salix Bair
SubscriberI am running Windows 10Â
July 3, 2023 at 3:30 pm
Forum ModeratorPlease post the top 5-6 lines of your injection file. I copied the header from the offline documentation and then added a couple of lines to create an injection without issue.Â
July 5, 2023 at 7:54 pm
Salix Bair
SubscriberHere is my injection file:Â
(injection 12)
(      x      y       z       u       v       w   diameter       t   mass-flow     mass   frequency     time     name)
(( 1.0000e-02 Â 6.0000e-04 Â 0.0000e+00 Â 2.0000e+00 Â 0.0000e+00 Â 0.0000e+00 Â 1.0000e-08 Â 3.0000e+02 Â 1.0000e-20 Â 5.2266e-22 Â 1.9133e+01 Â Â 0.0000e+00) r=1mm:0)
(( 1.0000e-02 Â 6.0000e-04 Â 0.0000e+00 Â 2.0000e+00 Â 0.0000e+00 Â 0.0000e+00 Â 4.5426e-08 Â 3.0000e+02 Â 1.0000e-20 Â 4.8991e-20 Â 2.0412e-01 Â Â 0.0000e+00) r=1mm:1)
(( 1.0000e-02 Â 6.0000e-04 Â 0.0000e+00 Â 2.0000e+00 Â 0.0000e+00 Â 0.0000e+00 Â 1.1628e-07 Â 3.0000e+02 Â 1.0000e-20 Â 8.2166e-19 Â 1.2170e-02 Â Â 0.0000e+00) r=1mm:2)
(( 1.0000e-02 Â 6.0000e-04 Â 0.0000e+00 Â 2.0000e+00 Â 0.0000e+00 Â 0.0000e+00 Â 1.0019e-06 Â 3.0000e+02 Â 1.0000e-20 Â 5.2566e-16 Â 1.9024e-05 Â Â 0.0000e+00) r=1mm:3)
(( 1.0000e-02 Â 6.0000e-04 Â 0.0000e+00 Â 2.0000e+00 Â 0.0000e+00 Â 0.0000e+00 Â 4.2611e-06 Â 3.0000e+02 Â 1.0000e-20 Â 4.0436e-14 Â 2.4730e-07 Â Â 0.0000e+00) r=1mm:4)Getting this error:Â
Error Object: injection
July 6, 2023 at 7:49 am
Forum ModeratorLook very carefully at the second sample format in 21.3.13.1 and count your brackets.Â
(z=4 12)
(x y ....................... name )
July 11, 2023 at 4:04 pm
Salix Bair
SubscriberSo I realize that I was mixing my injection formats, I'm pretty sure I have the spacing and formatting correct now:Â
(z=4 12)
(x y z u v w diameter t mass-flow mass frequency time name)
(1.0000e-02 6.0000e-04 0.0000e+00 2.0000e+00 0.0000e+00 0.0000e+00 1.0000e-08 3.0000e+02 1.0000e-20 5.2266e-22 1.9133e+01 0.0000e+00 r=1mm:0)
(1.0000e-02 6.0000e-04 0.0000e+00 2.0000e+00 0.0000e+00 0.0000e+00 1.0000e-08 3.0000e+02 1.0000e-20 5.2266e-22 1.9133e+01 0.0000e+00 r=1mm:1)
(1.0000e-02 6.0000e-04 0.0000e+00 2.0000e+00 0.0000e+00 0.0000e+00 1.0000e-08 3.0000e+02 1.0000e-20 5.2266e-22 1.9133e+01 0.0000e+00 r=1mm:2)
(1.0000e-02 6.0000e-04 0.0000e+00 2.0000e+00 0.0000e+00 0.0000e+00 1.0000e-08 3.0000e+02 1.0000e-20 5.2266e-22 1.9133e+01 0.0000e+00 r=1mm:3)I'm still getting an error when I try to read it in.Â
I also tried:Â
(z=4 12)
( 1.0000e-02 Â 6.0000e-04 Â 0.0000e+00 Â 2.0000e+00 Â 0.0000e+00 Â 0.0000e+00 Â 1.0000e-08 Â 3.0000e+02 Â 1.0000e-20 Â 5.2266e-22 Â 1.9133e+01 Â 0.0000e+00 Â r=1mm:0)
( 1.0000e-02 Â 6.0000e-04 Â 0.0000e+00 Â 2.0000e+00 Â 0.0000e+00 Â 0.0000e+00 Â 1.0000e-08 Â 3.0000e+02 Â 1.0000e-20 Â 5.2266e-22 Â 1.9133e+01 Â 0.0000e+00 Â r=1mm:1)
( 1.0000e-02 Â 6.0000e-04 Â 0.0000e+00 Â 2.0000e+00 Â 0.0000e+00 Â 0.0000e+00 Â 1.0000e-08 Â 3.0000e+02 Â 1.0000e-20 Â 5.2266e-22 Â 1.9133e+01 Â 0.0000e+00 Â r=1mm:2)
( 1.0000e-02 Â 6.0000e-04 Â 0.0000e+00 Â 2.0000e+00 Â 0.0000e+00 Â 0.0000e+00 Â 1.0000e-08 Â 3.0000e+02 Â 1.0000e-20 Â 5.2266e-22 Â 1.9133e+01 Â 0.0000e+00 Â r=1mm:3) -
July 12, 2023 at 7:57 am
Forum ModeratorThat looks fine, I assume it's all one line in the text editor? I wonder if frequency should be 1? We don't use files all that often (VOF to DPM is the exception) and I can't remember what it's exact purpose is.Â
(z=4 12)
(1 2 3 1 2 3 1e-5 300 0.001 0.1 1 0.001 injection:99) -
July 12, 2023 at 4:09 pm
Salix Bair
SubscriberI just tried with the frequency equal to one and as all one line, I thought each particle had to be a separate line, but still no luck. I think it might be time to try to pivot to a different solution for what I am trying to do... I am trying to create an even distribution of 500 particles over a large range of particle diameters to be injected from a single point. The linear diameter distribution option creates a distribution of particle diameters that is skewed to larger sizes. Is there a way in the set injection properties box to define an even distribution?Â
July 13, 2023 at 3:01 pm
Forum ModeratorI don't think so, and you're also looking at parcels rather than particles on the injection so it's a little messy.Â
Try without the = in the parcel name.Â
July 19, 2023 at 10:52 pm
Salix Bair
SubscriberHi Rob,Â
I tried it with the = in the parcel name, and that didn't seem to change anything. I think in an earlier post you had maybe said it was the text editor I was using, I'm using windows notepad...
July 20, 2023 at 7:57 am
Forum ModeratorTry Notepad++Â or something where you can show white space characters. It's the |P like symbol (View>Show Symbol in the newer version of ++). If you copied the header from the manual you're almost certainly going to have picked up a symbol or few.Â
We tend to use ++ because it also shows up all the useful { } pairs and colours by command syntax once you save in a certain format, ie .c Â
July 20, 2023 at 8:55 pm
Salix Bair
SubscriberI just switched to Notepad++ and I've gotten the closest to getting Fluent to read in the injection...I'm still getting an error, but fluent is now reading in the first argument:Â
Importing the following injections:
0.01
Error: ASSQ: inInvalidrgument [2]: improper list
Error Object: 0.0005999999999999999
I switched over to this format as well: (( x y z u v w diameter temperature mass-flow) name )Â
July 21, 2023 at 8:36 am
Forum ModeratorDo you need a parcel name? I've always used the other format. Also check the injection point is some distance into the domain, that should give a different warning but worth eliminating a potential issue when testing.Â
July 21, 2023 at 7:30 pm
Salix Bair
SubscriberFrom the user guide: All the parentheses are required, but the
nameis optional.ÂThe injection is well into the domain. I'm injecting at x=10mm, and y = .6mm in a 60mmx2mm rectangle.
July 25, 2023 at 8:32 am
Forum Moderator2d? What happens if you remove the z coordinate & velocity header and values?Â
July 25, 2023 at 9:22 am
Forum ModeratorOK, don't. A colleague just tried it and 2d does still add a z & w component.Â
On re-reading the error it looks like Fluent is reading injection 0.01 and then failing.Â
- The topic ‘Writing Injection files for DPM’ is closed to new replies.
