October 16, 2024 at 1:51 pm
1546225070
Subscriber自振频率在20阶之后就变化不大,是模型出错了吗,可以帮忙看看命令流吗
October 22, 2024 at 12:00 pm
ashish.khemka
Forum ModeratorHello,
Can you explain why you are going till 20th order? In most cases, high frequency modes can be neglected. And not every mode participates at the same level to the deformation of the structure under dynamic load. Please refer to the following link for more details:
Mode Participation Factor and Effective Mass — Lesson 4 - ANSYS Innovation Courses
Ashish Khemka
November 4, 2024 at 2:21 am
frank.wang
Subscriber查看一下前20阶的振型参与百分比,是不是达到要求了。通常桥梁结构需要达到90%参与。 如果没达到90%,检查模型20阶以后的振型是否均为局部振型, 如果为局部振型可以考虑增加模态数或者暂时去掉这些局部振型参与的杆件。模态分析包含过多结构细节意义不大,一般以把握整体振型为主。
- 您必须登录才能回复此主题。
