June 13, 2023 at 2:50 pm
Ryan J.
SubscriberHello,
I am trying to export results from my workbench/mechanical project by going to the Result Summary Worksheet and then exporting to a text file like I've done in the past but when I add new probes to my solution they are not showing up in the summary worksheet or the exported text file.
The project I am working on was pulled up from 19.2 into 2022 R2.
I've check the user guide and the results I am trying to export (joint probe - friction moment) should be acceptable.Â
I would really appreciate any help with resolving this as it would save from manually transcribing all of my result to Excel.Â
Thanks!
June 14, 2023 at 10:25 am
Aniket Chavan
Forum ModeratorSo are you not able to see newly added results or some specific result?
-Aniket
June 14, 2023 at 12:09 pm
Ryan J.
SubscriberWhen I add new joint probes to my solution they only appear in the result summary if they are scoped to a result type other than Friction Moment.
- The topic ‘Worksheet: Result Summary – Not all results showing up’ is closed to new replies.
5899
1306
