TAGGED: #fsi-#transient, fluent, mechanical, workbench
December 30, 2024 at 11:29 am
EO
SubscriberHello!
I am new to Ansys and I am using it as part of my dissertation related to obtaining the force-deflection curve of a rolling lobe air spring. Effectively, I am interested in the vertical component of pressure acting on the bumper for a given vertical displacement of the bumper above some reference position. [See schematic & video of rolling lobe air spring below]
To start with, I want to ask a couple of questions:- What workflow is best suited for this problem (i.e One way FSI, Coupled Fluent & Mechanical)
- Where can I find resources on Dynamic Meshing and setting contact regions in fluent
I look forward to hearing from you!
Kind Regards
P.S - I apologise if my question has not been posted to the correct channel
ÂÂÂ -
January 6, 2025 at 2:07 pm
Rahul
Ansys EmployeeYou can use two-way coupling of Fluent and Mechanical for this.Â
To learn the workflow you can refer to the following documentation:
Reed Valve FSI Co-Simulation with Partial Setup Export from Workbench (Fluent-Mechanical)
Analyzing FSI with ANSYS Fluent and Mechanical - Part I - YouTube
Analyzing FSI with ANSYS Fluent and Mechanical - Part II - YouTube
Chapter 42: Performing System Coupling Simulations Using Fluent
5734
