Workflow Advice: Rolling Lobe Air Spring Force-Deflection Analysis in Ansys
December 29, 2024 at 11:00 pm
EO
SubscriberHello!
I am new to Ansys and I am using it as part of my dissertation related to enapsulating the force-deflection behaviour of rolling lobe air springs as it deforms. Effectively, I am interested in the vertical component of pressure acting on the bumper for a given vertical displacement of the bumper from some reference position. [See schematic & video of rolling lobe air spring below]
To start with, from this thread, I would like following information:
- What workflow is best suited for this problem?
- From my initial research it seems as though this type of problem is best suited for FSI (Fluent) in workbench
- Pointers to good resources on understanding Dynamic Meshing & Contact regions in Fluent
Thank you for reading my post, I look forward to hearing from you.
Kind Regards,
Erhu
Video of Rolling Lobe Air Spring under load
ÂÂÂÂÂÂ - What workflow is best suited for this problem?
January 14, 2025 at 10:57 am
nilay.pedram
