July 16, 2024 at 11:54 pm
J.T.
SubscriberUpdating desing points is not working and requires manually stepping through sequentially for each design point. Are there settings that allow this to run more robustly?
The current setup seems to stop on the first meshing step but no manual intervention is required other than hitting generate mesh. The remainder seems to work fine but this manual intervention is required for every design point.Â
July 23, 2024 at 3:11 am
mjmiddle
Ansys EmployeeIf you turn on the messages in workbench ("View > Messages") what is the error where a Design point fails? Are you running through Remote Solve Manager (RSM)? You may try resetting the Ansys cache to all defaults. Type %APPDATA% in the Windows search field, which should take you to a folder such as:
C:\Users\{login}\AppData\RoamingGo into the Ansys folder and delete or rename the Ansys version folder while all Ansys products are closed. For Ansys 2024 R1, this would be v241.
When you launch Ansys the next time it will write all defaults to the location.
- The topic ‘Workbench update design points does not update’ is closed to new replies.
4798
1571
1386
1242
